Jun 19, 2020
DIY or Homeowner
Hi - I had a low profile shower installed professionally some 4 years ago. The hi flo drain keeps clogging up. Last time we eventually cleared a bit of it when a 'plug' of gunge came out that was the shape of the inside of the pipe - ie, it had congealed and formed like an inner blockage - I'm sure the other half remained but we'd had enough by then. We'd stuck everything up and down - from inside and outside - and also used hose pipe under pressure, both ends with towel wrapped around, and plunger. Its on an outside, ground floor room, so easy access. Today I bought a stainless steel 'snake' to shove down, but couldnt get it in. We're talking 3 months since I last tried to clean it. Only used by my husband who hardly has any hair, so its mainly soap gunge probably. Anyway, main reason for posting is, the problem for me is that I don't seem to be able to find any trap that I can take out - the only way to get to it would be to remove the tray, which ofcourse is ridiculous. Any ideas? Thanks all. (ignore the white, its not dirt or scale its talcum powder - didnt notice it til I uploaded photo)
Dont like them wastes.
Could possibly be not enough fall on pipe.
No, I don’t like it either. I remember they did discuss the fall at the time, I think that’s right. But it did use to work OK so it obviously is clogged - but how do I get access? Is there no more access? Why don’t you like them? Completely useless if you can’t get access for cleaning - makes it expensive if you have to lift the shower tray every few weeks to clean it!!
That’s one of the “vortex” type wastes and there is nothing you can dismantle.
Like Simon, I don’t like this type of waste as it can be very difficult to clear when blocked.
As you spear to have access from outside- have you tried a wet vac?
Hold a wet vac over the waste pipe using a damp cloth and you hand to make a good seal. Have someone inside to pour warm water into the shower outlet.
Brilliant. Thanks. Yes, I remeber now, Vortex. Thanks so much for confirming nothing more to dismantle. And yes, I do have Vax machine in a pile waiting to car boot, so will give that a try. Brilliant.
W
1K
