C
chrisc1881
Hi all. I'm one of the other mob (electrician) and I could really do with some advice please.
I bought a self install Hive smart thermostat and thought I'd fit myself as a plumber friend of mine told me it should be fairly straightforward. He's now :50: off on holiday and it's not straight forward.
The issue I have is with the wiring at the programmer. The Hive wiring diagram has 6 terminations to be wired to, Live,Neutral,1-hw off,2-ch off,3-hw on,4-ch on.
IMG_3109.jpgIMG_3108.jpgIMG_3120.jpgIMG_3111.jpgIMG_3112.jpgIMG_3115.jpgThe existing programmer has the same terminations but there is no cable in the 2 termination. I wired it as the existing but the heating won't come on without the hot water and I have to move the lever on the 3 port valve to the right and hook it up to stay. Then I can get heating. I also disconnected the old thermostat and made safe in blocks. all the Hive stuff is up and running, so I know its an issue on the wiring that I need to correct. I hope!!
The boiler is an Ideal Logic Heat 15. Not a combi system. I believe its a regular system. I have an immersion as well. The old programmer is a Honeywell ST9400S1001 that had an old Honeywell thermostat connected to it with 3 wires. I have attached some pictures if it helps.
I would be grateful for any support. Thanks in advance.
Chris
No, I disconnected at the old thermostat and put cables in seperate connector blocks. I assumed the old one had to be disconnected so the the temp could be set/adjusted by new one. Otherwise its still being controlled by old. No?
Forgot to mention that the old thermostat had 3 wires and there is also a pump (shower type). I live on 4th floor with only mains to kitchen cold. The rest sinks/toilet/shower activates pump for water. Don't know if this helps, just want to give you as much info as poss.
I've now connected the old thermostat wiring and turned heating on with hot water off and boiler has fired up. Will post back in a bit.
Update:
All sorted thanks for the help. It just needed the old stat wiring to be connected to enable the 3 port valve to operate as it should when called for heat.
