just crack the rad nut and use you wet n dry to suck up the rad contents, flick rad upside down and walk it out. No spills, no mess, no doing your back in! simples
Reactions: 2 people
Thanks for the heads up Danny. Bought one today. Thanks to mike for the idea too 2013-04-02 16.04.02.jpg
Reactions: 2 people
I knew you'd all catch on eventually. You should have a non return and isolator on them really though folks.
P.s. this sprayer is about £6 at stax.
is this quicker than drainging a small amount of water from a towel rail, then topping up with chemicals??
invest in a listening stick, can help locate partial blockages. open all lockshields and trvs etc full then go round accessible pipework putting the stick on it. you usually get louder velocity noise in the local of a restriction.
pls post a link
Clean up after you've finished a job, even if the lady or gent of the house says it's fine.!!!
Check that all controls etc. are working before you start a job so that you don't get stitched up when they don't work afterwards.
Reactions: 4 people
