re: Hints, tips & secrets of plumbing - No Banter please!
Get a short piece of copper pipe with a stop end on to slide over your hot blowlamp nozzle when used in case it gets knocked over.
handy if you got the rothenberger blowlamp with the tip that goes red when soldering!!!!!! much prefer the bernzomatic!!
do everybody else's do this or just mine?? the bernzomatic tip stays coldish all times, but the rothenberger jest goes red hot straight away when i solder a joint!
Mine only gets red (glowing) hot if I turn the flame right down.
It always gets hot though! It's a blow torch.
I use Mapp gas BTW.
mine goes red whatever i try to do!!! i always use mapp gas with it, the bernzomatic tip doesent get red or hot tho!
allways carry an extra roll of solder in the van, don't know how many times that one has bitten me
Mine doesn't mate. If I'm sweating a joint and want to be careful with it, I'll wind the gas right down. Only then will the end start to glow red.
when you fit a bath dont use the L shaped brackets there useless and you will get alot of movement from the bath, instead level the bath put a pencil line around the top of the bath ease the bath out of place and apply PINK GRIP adhesive about 10mm below your line, use plenty of it then throw your bath in place, give it a good wiggle to ensure it grips, if any goes on the bath dont rub it off, let it cure an it will just break off in go, (same goes for expanding foam if it gets on your hands dont rub it, let it cure an peal off in one go)
I pity the poor fitter, who, in years to come, goes to remove one of your baths!
As for the "L" brackets, the problem with them is potentially splitting the wooden batten if you screw through without first pre-drilling. Also so many fitters (for ease of installation) put the bracket facing upwards (and then tiled over). Makes it a right pain if bath is to be removed without disturbing the tiles above!!
Why not put one bracket at each end (of the long side near each end) then one each on the near side, four brackets = bath reletively secure without the need for any adhesive, dont forget to use the lock bolts on the legs (they help stabilise as well and (before you tile) a sufficient but small amount of clear silicone between the bath edge and wall.
This silicone will be thin enough to secure but not enough so as to make it impossible to remove the bath without destroying the wall behind.
The finishing silicone then becomes a waterproofing and decorative layer and although it will also provide some mechanical grip that is not is what is intended, thus this top layer does not become stressed and fail causing a leak path.
www.iiplumbing-services-derby.co.uk
Reactions: 2 people
Typical Plumbers post well done , unfortunatly all the builders that do bathrooms will never read this , or they will never listen to any plumbers advice
Why not put one bracket at each end (of the long side near each end) then one each on the near side, four brackets = bath reletively secure without the need for any adhesive, dont forget to use the lock bolts on the legs (they help stabilise as well and (before you tile) a sufficient but small amount of clear silicine between the bath edge and wall.
I can’t take full credit for this as I got the idea from another forum member who mentioned he had made one of these.
He didn’t detail how.
This ‘fence’ sprayer comes from Screwfix. It’s on special at the moment for £18.
If you remove the spray wand, a piece of 10mm copper tube fits in perfectly, and seals with the supplied O ring. Then screw on the back nut that comes with the sprayer, which also has a compression piece to hold the assembly tight. On the end of the 10mm pipe, I've got a 10/15mm compression adapter that I got supplied with a load of rad valves I bought. I've then got a 15mm compression coupling. Which is perfect for attaching a filling loop hose.
You then have your own dosing tool for sealed systems. You can use cheaper bottled chemicals and still put them in under pressure.
I initially tried using a reducing ‘bush’ on the male end of the fitting, but a 10mm bit of tube is miles better.
You also get the handle which you squeeze to activate the pump.
Anyway, get down Screwfix and buy one of these. They’re normally £25.
Reactions: 3 people
i just use a 15 to 22 mm connex coupler with a 22 mm full bore flexi tap connector screwed on to it and from that a small stub of 22mm with a 22 to 28mm reducer on it, a few loose bits i had knocking around the van one day
Reactions: 2 people
I posted this tip before, but I'll do it again with a pic. Struggling to get PTFE on lagged cylinder unions? Wrap PTFE around a pencil, then use the pencil to apply the PTFE to the threads..............
Reactions: 16 people
This is a great tip! Although I'm not sure why you'd need ptfe on cylinder unions.
