L
lame plumber
unless you use tectite and their little keying tool so it has a gripper ring cut into the chromedont put pushfit on chrome pipe.......ever
**** happens mate. No one died and stuff is replaceable.
ive been using "frame fixers" or whatever they are called to fix wc's to floor lately! simple job! just fut the flange off the plug! no faffing arounf with plugs not entering the holes you have drilled ect!!
What do you mean? Have you got a link please
These
Frame Fixings 8 x 80mm Pack of 10 | NoLinkingToThis
They are not corrosion resist tho so someone will hve to break the pan out in a few years when the pysh rots the screw head.
What ever happened to using 4" No.12 brass slotted screws & raw plugs to fix a pan down, a Tamz ????These
Brass 3" 12's do me Chris. I certainly wouldn't use a frame fix.What ever happened to using 4" No.12 brass slotted screws & raw plugs to fix a pan down, a Tamz ????
Yes, sorry but the floors are not so good down here as the granite you may be use too TamzBrass 3" 12's do me Chris. I certainly wouldn't use a frame fix.
when fitting rads under a window sill measure down from the sill for top of bracket height fix brackets pop rad in place check levels and whichever side is the high spot pop the bleed valve on . I go to quite a few complaints (not my jobs) that are rads that seem un level when infact its spot on but they look out because of the sills
