Hints, tips & secrets of plumbing - No Banter please!
View the thread, titled "Hints, tips & secrets of plumbing - No Banter please!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
How does it work?
Keep the rad turned off? If you turn it on won't it just refill?
What am I missing?
It's going to be full of air... As the heating heats up, it compresses the air in the radiator and that takes the expanded water. It only lasts a week or so though.
So you keep the rad turned off? I'm still a bit lost on this one. How can it be used if it's full off? I understand it's full of air but the air is in the rad with both valves off so it can't go anywhere
Sorry if I'm still missing it!
I use these Bristan Bar Valve Wall Mount 10 Fixing Kit Chrome-Plated | Spares and Parts | NoLinkingToThis the fitting is actually this side of the tile – no need to worry about any leaks, cos it’s all soldered behind the tile.
ae235
Reply to the thread, titled "Hints, tips & secrets of plumbing - No Banter please!" which is posted in UK Plumbers Forums on Plumbers Forums.
REDSAW,
firemant,
