Guest viewing limit reached
Hot tap won't turn off
View the thread, titled "Hot tap won't turn off" which is posted in UK Plumbers Forums on UK Plumbers Forums.
sibs
Hi I have a mixer tap in the kitchen with levers. Pull each lever down to turn on and up to turn off - so I think it might be one of those ceramic disc taps ?? Anyway the hot water tap won't shut off - ie you push the lever up but the water stays on (thank heaven for service valves)
Does anyone know what might be wrong? Will I need to replace the whole tap?
Thanks sonray
A few more questions - is a cartridge easy to replace?do I need to know the make of the tap? Are the cartridges easy to find ie plumbers merchant/diy shop? What if I don't know the make?
You do need to know the make to order a new cartridge. If the tap originally came from one of the sheds you may find that you can't get spares.
Mike
yes they unscrew like a normal tap insert
yes make/model of tap is needed.
or can you give us a pic of the tap and a pic of the cartridge.
maybe able to put a name to it or cartridge number.
Thanks guys... sorry can't find digital camera also not my tap and house is no within popping round distance. I severely doubt she will know the make of the tap so does that mean its a new tap?
Thanks everyone....have fixed the tap.... was easy and found the spare part I needed in B&Q after going to two plumbing shops - wouldn't ya know it 🙄
Thanks for all your help
Reply to the thread, titled "Hot tap won't turn off" which is posted in UK Plumbers Forums on Plumbers Forums.
sibs,
sibs,
