View the thread, titled "Hot water, but only just" which is posted in Bathroom Advice on UK Plumbers Forums.
Got a Worcester combi boiler that gets serviced every year through BG, but we are finding that the hot water is never that hot.
I think the water is passing through the boiler too fast and doesn't get a chance to heat properly.
Very noticeable on the bath, where we have to close the tap down quite a bit until the flow rate reduces coming out the tap.
Is there a way to reduce the flow rate as it goes through the boiler?
Even though to get hot water you need to close the tap to a trickle but believe you can get adequate flow - albeit if cold, the alternatives are simply that either the **amended as mentions boiler repairs**. I realise that either of these should affect the total flow and not just hot flow, but I have seen exactly this symptom on a W-B 34 combi in a very hard water area (Bath). If either prove to be the problem, you could - after fixing - also install a CombiMate to help reduce its tendency to scale the DHW side (the CH side should not scale).
Reply to the thread, titled "Hot water, but only just" which is posted in Bathroom Advice on Plumbers Forums.
