M
mrplumberman
i,ve just fitted a new toilet.when you flush the loo the boiler fires up.any ideas?
as the guy is going nuts.
Bye the sounds of this saga you have cocked right up but the only saving grace you may have is if you have mixed all hot and colds up you can cross at boiler if not get ready to start ripping up tiles and sort it would you pay if it was done in your house don't think so
If it came to the bit and ya had to rip bathroom apart, where would you stand with insurance??
i,ve never had this happen before.and iaint running mate as the guy owes me doh.if i swap pipes at the boiler and washing machine would that sort it?
This reminds me of advice given to me by my ex boss when I'd screwed up big on a job. He took me to one side and said, "At the end of this year are you going to look back and say that was the job that ruined me? If the answer to that is no then you've just simply got to grin and bear it - get on with it, do whatever it takes to sort it out, leave everyone as happy as possible and move on."
Reactions: 2 people
Now that's good advice
without knowing the piping layout then we couldn't possibly say, well i couldn't anyways, You metioned electric shower earlier in thread and i've asked a couple times does combi fire up when in use and still awaiting an answer
Crossing feeds is easy. Everyone has done it. Luckily I've so far noticed when I run the taps or fill the loo before tiling begins. It pays to be a bit paranoid in plumbing. Check everything repeatedly, all the time. Suspect everything, every noise. Work on the assumption that every inanimate object is out to ruin your day and you should be ok.
Reactions: 4 people
agree totally
Good advice
Its best to check and double check then check again to be sure only takes 5 mins
flats often share tanks - bit remiss not to check
you may be able to sort out his prob (or divest yourself of responsibility) with relative ease - if it's just crossed feeds i'm sure something can be done. but re-instating the CWSC to the lady downstairs could be a bigger faff.
