Hot water from new boiler
View the thread, titled "Hot water from new boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
I have recently had a Worcester Bosch 30CDi system boiler installed and am trying to estaimate how much time I should have the boiler on to get a constant supply of hot water.
My previous boiler was an 18kW baxi boiler which I had running for around 90 mins morning and evening on quite a low setting, which gave me adequate hot water for everything for baths showers etc, but probably needed a 1 hour boost when more than 1 person was taking a bath.
Considering the significant extra power of this boiler, I have been running it for 50 mins twice a day with the boiler setting on 5. The digital display on the boiler is showing 55.
However, the water is simply not getting as hot as I feel it should be. What settings and timings should I be using to heat a typical tank up to a temperature where the airing cupboard feels warm when it's opened?
I am not using central heating at the moment.
You need to set your cyl stat about 60c Boiler stat 65/70c Boiler with 30Kw should heat your cylinder with in 20mins ! did you have the cylinder replaced for a HE type ?? What was the reason for fitting a larger output boiler ?
Cylinder stat set at 65.
Reason for having more powerful boiler was installer recommended this because it had a longer guarantee, for not much extra cost.
Cylinder was not changed.
Boiler stat just has a number rather than a temperature.
How old is the cylinder? Might have been better to get same size boiler and spend the extra on a high efficiency cylinder.
As Simon Johns said if you have your cylinder stat set it will knock boiler off when cylinder is warm enough.
Do you have 2 x 2 port valves or 1 x 3 port?
I only ask because a 3 port will only flow 11kw so you would need to have 2 x 2 port valves fitted to take advantage of the higher output boiler.
I've changed the settings as suggested by jtsplumbing. Seems to be a lot better now.
Manchestergas, I'm afraid I haven't a clue.
Reply to the thread, titled "Hot water from new boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
peter lanky,
peter lanky,
