How do I connect a diverter to a Grohe tap?
View the thread, titled "How do I connect a diverter to a Grohe tap?" which is posted in Bathroom Advice on UK Plumbers Forums.
Hello,
I’m trying to fit a diverter to a Grohe concetto single hole mixer tap. I have removed the aerator but cannot find any adapter that will fit as the opening is at an angle. The removed aerator is F22 female and screws onto plastic threads that look like a hexagon when looking up into the tap. I’m wondering if that plastic piece can be removed which may make the tap become a female connection instead (which I have an adapter for).
Any help is much appreciated.
That diverter is meant to replace an F22 aereator.
You will need to use an M22xM22 adaptor -https://www.aqua-techniques.fr/PBSCProduct.asp?ItmID=30025344&AccID=19102&PGFLngID=0&gclid=CjwKCAiAkJKCBhAyEiwAKQBCkvqBbpBjJhdAzfpKv1OEyJy%2DiI1v%5FBxsThH2r9dFIEpQbLa7DCMcnhoC4qQQAvD%5FBwE
***.and why every other country in Europe just uses mains pressure balanced hot and cold water supplies, with the backflow protection at the water company's meter.
you can do that here and then install what you want you need to install a break tank and pump eg dab e systank and pump
then you can install what you want
Reply to the thread, titled "How do I connect a diverter to a Grohe tap?" which is posted in Bathroom Advice on Plumbers Forums.
noviceneedshelp,
ShaunCorbs,
