Shires Lynx
the issue is that you are asking for advice on how to connect something to the water supply that is slightly out of the ordinary. there are regulations in place to ensure the water supply does not get contaminated, what you suggest seems worrying.
if you gave more of a description as to why you want it to work perhaps the replies may be closer to what you wanted.
the process of making the connection you want is very simple, the issue is whether you should make it.
Well I did say in my original post I am a cistern collector, and just have a general interest in seeing cisterns work the way they should. That's why I want to connect a water source from a sink tap to the actual float valve instead of just getting a jug and filling the cistern up.
It's just a hobby - nothing serious and will not be used for anyone else nor by anyone else.
