Oct 13, 2019
DIY or Homeowner
I purchased an overflow bath filler and taps but struggling to see how to connect that taps to the actual overflow filler. I've included a picture of what has been sent to me and any help would be much appreciated.
I have looked everywhere online for some instructions but to no avail. I am guessing I need some sort of tee connector and additional connector pipes but struggling to find anything that looks like it will fit.
You need a female either 1/2" or 3/4" BSP to either compression or pushfit depending on what type of pipe you intend to use. I can't tell for sure what sizes you have there but hopefully someone may be familiar with your kit and know the sizes but they look like 1/2" to me.
Like this Elbow UK Compression - 15mm x 1/2" - 6691 | BES.co.uk
And this - Tee - UK Compression x Compression x BSP F - UK-7316 | BES.co.uk
They also do them in straight couplings and tees with one branch as the female and the other two compression or pushfit to connect to pipe. You can get them in pretty much any combination to suit your layout and valves.
Reactions: Lou
I've not seen one like that before but would expect there to be a manifold connecting Hot, Cold and the filler, with non return valves in.
Alternately it would be made up of copper pipe and fittings so the position of the taps and waste could be in various positions.
Thanks for your replies. I think a combination of the fittings Stigster suggested and some 15mm copper pipe should do the trick.
Cheers
Reactions: Stigster
