How do I remove this radiator thermostat?
View the thread, titled "How do I remove this radiator thermostat?" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Hi, I’m looking for some advice on how to remove this radiator value to check if the pin is stuck. I have two similar values in the house where those radiators aren’t heating up at all. The pipe leading into the value is cold but the rest of the system is working fine.
Thanks for any help/advice!
Only goes one way so try the other way sorry can’t remember which way I think you have to twist towards the wall
There was a little plastic tab that needs sliding out with a small screwdriver, then it popped off nicely. Pin given a tap and it’s fired up the rads. Won’t go in and out too easily but heating is on at least. Thanks for the answer as that got me over the line!
Try some 3 in 1 oil on the pin
Reply to the thread, titled "How do I remove this radiator thermostat?" which is posted in DIY Plumbing Advice on Plumbers Forums.
Stuart Norman,
ShaunCorbs,
