Nov 3, 2019
40
DIY or Homeowner
The bathroom basin mixer tap was installed without a chrome washer to hid the joint between it and the porcelain sink, which didn't look very nice.
I bought the biggest chrome washer I could find and then turned out the inner diameter to fit the tap column.
Of course, having removed the chrome from. the insiful!
Is there a product I can get that will stop the rust, seal it?
Short term Kurust or this might help:
A longer term fix would be to send it to a chrome plating outfit!
I find red oxide primer to be one of the longer lasting anti-rust paints.
You might also find Waxoyl (the yellowy waxy liquid you spray into box sections of motor vehicles) would work well in your situation.
I'm pretty sure this is a Vado Photon Mono Basin Mixer Tap. Its column diameter is 1.827", just over 46mm.
The nearest I could find. was on Amazon. I couldn't find anything from Vado.
Might be worth asking Vado customer services if they can obtain/send you one?
Pictures of that model sometimes show it and sometimes don't 🤔?
As an Amazon Associate we earn from qualifying purchases.
