How much would you charge....
View the thread, titled "How much would you charge...." which is posted in UK Plumbers Forums on UK Plumbers Forums.
Inverness
on a Worcester greenstar 30si to replace new expansion vessel and a new prv, which means to remove the hydroblock nightmare of a job. The prv lever is loose it does not operate which needs replaced.
I'd like to know roughly the labour you would charge so I don't under rate myself.
Easiest way to do this, would be get a bag of 1/2 and 3/4 washers. Undu the top nuts off the valves, remove the flue and lift the boiler off the jig.
Easier to remove the boiler to be honest, will take you around 2 hours plus travel etc, depends where you are but id be looking around £100 for Labour.
Which is apparently optimistic 😀
If not, you’ll need all the seals to start stripping the hydro components out of the boiler.
uck repairing boilers , its a nightmare , there are sometimes no winners , the job and parts can cost almost as much as half a new one, it has to be carried out I know but its a nightmare for all
Rob Foster ..chking
Rob Foster ..chking
Lol, it’s divides the wheat from the chaff. I personally like to repair, it’s very satisfactory fixing something.
Reply to the thread, titled "How much would you charge...." which is posted in UK Plumbers Forums on Plumbers Forums.
Inverness,
Sharp Point,
