How to connect this black pipe?
View the thread, titled "How to connect this black pipe?" which is posted in Bathroom Advice on UK Plumbers Forums.
Hi All,
These push fit type pipes are in the bathroom, they twist but I was not able to disconnect the long 35mm black one - quite tight fit.
Is there any compression type connector or flexible connector I can use to connect these two pieces or any transition to 40mm system?
I have cut it to be able to raise the trap and connect to the new basin which turns out to be higher than the old one.
Is this what I am looking for?
Coupler 32x32mm
The transition?
32 to 40mm connector
For some reason it does not allow me to post links in here.
Please advise.
Reply to the thread, titled "How to connect this black pipe?" which is posted in Bathroom Advice on Plumbers Forums.
JohnMalcolm,
ShaunCorbs,
