A
ar22
My boiler is in my garage and I want to plumb one radiator off it in the garage
The boiler is really tight to the wall and the pipe work is to the wall side so very awkward to tap into
So I have drawn up two plans that might be feasable
Plan A is tapped off the flow side coming out of the boiler that goes up to the pressure expansion vessel, the return is into spare inlet on the easy to get to (might need a non return valve here ??)
Plan B works on the principle of convection
which one can I use or is there a better idea ? or will either work just as well as each other ?
any advice would be greatly appreciated
