May 9, 2019
23
DIY or Homeowner
Hi I wonder if anyone can give some some advice.
Moved into my house 3 weeks ago and over the last week I have noticed I can hear water running in the cold water pipes in the bathroom, airing cupboard and down by the stopcock in the kitchen.
We have changed the float in the tank in the loft and whilst the stopcock was off the noise stopped. We have turned all of the appliances off and we can still hear the sound. Checked all taps. We cannot find where the source of the noise is coming from but we are pretty sure it’s it the cold water pipes.
I am really worried we have a leak somewhere. Any advice as to where it could be? Or if not is it normal to hear the sound of water in pipes?
I have NO idea about plumbing at all so any advice would be appreciated. We also do not have a meter in our house.
Thank you in advance!
It is not a trickling as it is a constant sound all of the time. To me it sounds like water but I couldn’t rule out that it is hissing. It that common of pipes to hiss?
It's hard to describe in words I know. If it stopped when you had the main stopcock off, it must be after that (obviously) and if nothing appears to be dripping, no ball cocks are passing etc, than you may have a leak. It might be time to get a Plumber to look into it for you.
Just another thought. Sometimes a burst below ground outside can be heard resonating through pipework. I have know that sound to deaden slightly on closing the stopcock but not very often. As I said and others earlier in the post, a Plumber should be able to track it down.
No worries. As Craig has said, are any of the cold water pipes heavily condensated? Only other location you might be able to check is under the bath panel, failing that, you may need to enlist a plumber.
We are just about to have a look on the pipes to see if they are condensated as this isn’t something we had thought of. Good shout on the bath panel thank you! Appreciate your advice!
Reactions: Burger
My partner thinks it is more of a hiss, it almost seems too constant to be a large amount of water as our loft tank is not draining. Thank you for your advice we are looking at all of these suggestions as we speak. Of course we will call a plumber if we can’t find out what it is but it’s really helpful!!
My dad did mention that actually, that the sound could just be travelling through our pipes. Again, it’s really helpful thank you for helping me out!
Reactions: Last Plumber
Just an update! We just turned the stopcock off and the noise reduces but it does not stop completely. I’m hoping this means that it could be before our house and we are simply hearing feedback from it. Also there is no condensation on our pipes. Thank you everyone for your advice as it has really helped us this evening!
Ah okay I see! I meant our cold water storage tank in the loft. I guess what I mean is that if it is the pipe supplying our house then The water board may help us out?
The pipe supplying your house is your responsibility. Only the boundary stop tap and everything before it is the water boards responsibility. Your best bet is to confirm whether you do or do not have a leak on your mains and then contact to your insurance company and see if your pipes are covered.
  • Agree
Okay thank you very much for your advice!
Depending who your water supplier is, they may still be able to assist, as a one off on your main. If it’s in the house they will not. See this for a bit more clarity: https://www.unitedutilities.com/glo...le-guide-to-pipes-drains-and-sewers-acc16.pdf
Why did you ask about the tank, is it losing water?
I did read this on our local water board website so I’m going to give them a call first thing tomorrow and ask. Thank you for the information.
We’re pretty sure it isn’t no! That’s the first thing we checked.
Reactions: Burger
I have contacted my water board and they are coming to look next Friday at the pipe between our stopcock and the one on the street. I think it’s possible we have a leak on the mains supply, if this is the case is my house at a big risk at the moment? I’m really worrying that it’s going to be left for a week before it gets looked at. They did mention that if it’s a small leak they may be able to fix it free of charge so I’m really hoping this is the case!
Don't panic. If you knew how much water was leaking all over the country you would be amazed. I am not saying that an underground leak like the one you may have can't do damage but it is unlikely in my opinion. I haven't come across that much damage caused by underground bursts during my working life.
If it is something they will not fix then you will need to employ a Plumber to sort it for you. It is your responsibility if it is on your property. They will advise you when they see you next week on the best course of action.
Underground water mains can be difficult to find and in a lot of cases they are better replaced. How old is the property?
Do you know what the main is made of?
