I'm about to. To move a radiator.
So to run through proceedure. Am I right if I say:
Remove carpet from area, place somewhere protected.
Identify joists from pattern of where nails go through floorboards.
Cut through floorboard you want to lift along where you imagine the joist runs and in the direction the joist runs.
Cut down the length of the floorboard either side up to the point of first cut along joist.
Using claw of hammer or other thin metal wedge lift board.
Work on pipes.
Replace, using screwed-in wedges if mistakes have been made and board needs additional support.
Have I missed anything out?
I will be using a recriprocating saw because I already have one and I watched my old boss lift hundreds with one without issue. I've heard circular saws might be better for not risking cutting pipes underneath, any tips for not cutting pipes underneath with a recripro saw?
Work on pipes.
