I wish to add a second boiler to my existing meter. Location 20m away.
View the thread, titled "I wish to add a second boiler to my existing meter. Location 20m away." which is posted in Boiler Advice Forum on UK Plumbers Forums.
I wish to add a second boiler to my existing meter. Location 20m away. Underground run. Can l use 32mm yellow pipe with copper tails at each end. Thank you in advance
Hi Shaun. Thank you for the reply. Both 9kw. Will the meter be able to supply that volume of gas....
So heat only boiler in theory yes you should be fine providing the gas safe engineer works out there pipesizing etc
It's a 6m3/h meter Shaun will that cope with 18kw.... Is there any reason l can't use 35mm plastic yellow gas pipe after the meter under the ground. Thank you. Matt
Yes stnd domestic meter
The gas engineer can but it’s a bit more labour in installing it as it needs special fittings and practices to terminate above ground
Reply to the thread, titled "I wish to add a second boiler to my existing meter. Location 20m away." which is posted in Boiler Advice Forum on Plumbers Forums.
Mattkee,
ShaunCorbs,
