I
impo
Evening all
a little advice needed please I have an ideal classic 250 ff boiler 17 years old,
fan starts to run
pilot lights no problem
then instead of 1 click followed by ignition of main burner I get a rapid clicking that I presume is the gas valve clicking in and out,
if I turn the boiler off and on again most times it will light ok
this has been on going for some time but is happening more often
all thoughts welcome
thanks mark.
are you gas safe register'd?
we no longer give advise to non gas safe registered people on the public forum. the only advise we can give is contact a local engineer.
Agreed.
You need a gsr in to look at your boiler. We cannot and will not give advice on the installation or repair of boilers for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a private message to either Gas man or Redsaw who will then check you and then give you access to the gsr private forum.
Thank you.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
