Oct 6, 2022
West Yorkshire
DIY or Homeowner
so no display purchased a new one that didn't work either sent it back, so I did some more research and thought what about the pcb the orange one, was in process of getting one when the the other day had the heat on it went off, dead phoned insurance they out engineer pcb was dead one day later new pcb all work and I have a display now, however it did go off do I just turned power off and on now works But I'm going to get the hive unit installed that way if the display does go which is common on these ill be ok.
It could be a loose wire either inside the boiler or outside, eg fused connection unit.
This reminds me of the time I diagnosed a fault with a PCB, replacement was £230.
Fitted and worked fine for a week before I got called back to same fault.
After some head scratching and tears over my newly toasted PCB.
I found a crack in the ignition lead near the case and a tiny black soot mark. I ordered one of those allong with another PCB.
Cost to customer £330
Cost to me £490
They probably complained about how much money us gas engineers make too!
