C
chaotic_j
Hi fellas,
Much to my dismay I find myself like so many others in a pickle with my Ideal Isar HE30, it is just my luck I am landed with one of these badboys and thus I find myself seeking your assistance!
Problem seemed to start last night/this morning, so fairly sudden. The boiler was installed in 2007 under Warm Front scheme. Nope, it doesn't look like they did a very good job! It is located in the kitchen.
Noticed last night radiators seemed to be constantly 'on' i.e. hot/warm, particularly downstairs, and this was well after the CH was set to be off..! 3.5 hours later to be precise.
Problem now is no hot water / only very lukewarm.
The shower was totally cold this morning, upstairs taps sort of lukewarm now, kitchen taps are hot for about 2 seconds then lukewarm/cold now.
If I turn the CH thermostat off and set CH control on boiler to min, still same.
The radiators on the other hand seem to work fine... wondering if the DHW is going to CH?
The boiler display shows "0" and then when you run the hot water tap it goes to "d" and the burner goes on.. so 'should' be working OK?
Wondering if, as I've read on this forum and elsewhere on the web it is the "diverter valve head"?
This looks very easy to replace from the installers manual i.e. turn off electricity to boiler, turn off gas supply, remove cover, replace diverter valve - reverse of previous steps.
Hope you can help! your thoughts?
