Ideal Logic+ 30 combi - timer or room stat off
View the thread, titled "Ideal Logic+ 30 combi - timer or room stat off" which is posted in Central Heating Forum on UK Plumbers Forums.
T
tomdrawsstuff
I have an Ideal Logic+ 30 combi boiler which was running fine up until a power cut earlier today. Now it's stuck saying "timer or room stat off" whilst in Winter mode and the central heating won't come on unless manually triggered by the thermostat by increasing the temp. I've tested the thermostat's (Salus RT500RF) connection to the receiver and that is working fine.
The dials on the boiler were set to the below and worked fine with no messages on the LED screen.
Preheat: off
Water temp: max
Central heating temp: eco
Mode: Winter
When we first moved in a couple of months back we did have a similar problem with the "timer or room stat off", however I figured out this was being caused by the thermostat having frost protection mode turned on. I've checked the thermostat and frost protection is turned off. I've toggled it on and then off again to see if this might clear the boiler but it didn't.
Could anyone offer any advice on this?
Thanks for replying. Yes it does and I believe I've done a reset correctly according to the instructions in the manual.
I don't actually know. What would I need to look for to find out? I can't see anything attached externally to the house in the vicinity of the boiler.
Reply to the thread, titled "Ideal Logic+ 30 combi - timer or room stat off" which is posted in Central Heating Forum on Plumbers Forums.
tomdrawsstuff,
Scott_D,
