View the thread, titled "Ideal vogue maxc32 efficiency level" which is posted in Central Heating Forum on UK Plumbers Forums.
Mines will cycle more than 'normal' I guess since it`s only used on manual, via Hive thermostat. We switch it on at normally 18-19c depending on the house/outside temps. We don`t have zones or timed settings. It`s left on 24/7 and the Hive is dropped to 12c instead of switching off at night.
I have the boiler heating set to 70c and drop it to 55-60c come Spring/Summer. I`m not sure if that`s the most efficient way for us to use the heating tho`.
It would be nice if they quantified or explained this better because the condensing effect only just kicks in at ~ 55C return temp, you would need to get the boiler return temperature down down to 45C get a reasonable condensing effect of say ~ 8% to give a boiler efficiency of 95% from ~ 87% at 55C.
Old thread I know but thought peeps might like the response I got from their tech team , although not much of one it has to be said.
I asked if the definition was written anywhere , just for my interest because at the time I was just starting using Opentherm with the Google Nest.
My SEL has worked its way up to 93% over the year 22/23 , with flow return temps anywhere from 43/36 to 49/39.
Just for interest by my calcs OT uses around 16% less gas in my house by my calculations.
Anyway this is the , short , response I got .
Hope it's of use
Hope it's of use
Hi, thank you for taking the time to write to them. For some reason I cannot see the screenshot, just your uploaded filename. Can you please reshare?
I just moved into a home with an Ideal combi boiler and my %age is around 44%.
This might be that response, its certainly one of their responses anyway.
@John.g - thank you!
Is the 55°C the return temperature or the flow temp?
I'm assuming it cannot be the main boiler flow temp, as otherwise they would surely write the in manual that optimal temp HAS to be below 55°C.
Its the boiler return temperature and condensing only begins at ~ 55C.
Reply to the thread, titled "Ideal vogue maxc32 efficiency level" which is posted in Central Heating Forum on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
D robinson,
John.g,
