deebright
hi, I had a job in where i had to use 2 plumbers, both gas safe registered.
one run a copper pipe from the meter to hob and to utility room ready for boiler installation. second plumber than supplied and installed the boiler.
the first plumber certified his work as for installation of pipe to the hob and connecting the hob and installation of the pipe to gas valve to which than boiler was to be connected. his drop tests were fine etc and all in order.
second plumber however messed up the flu and it now spits hot water at intervals. he refuses to certify his work he and says that its because the copper pipe installed from the meter is wrong as its soldered.( In areas where the copper pipe is concealed in dryling (app 5 linear meters) there are 5 ventilation grills (size 200*200).the rest of the pipe runs in veritcal riser which is fire rated and ventilated at the top of the building.)
He demands to see the other plumbers certificate as he claims he is not sure that installation is safe. If I don't give him the paperwork he will not certify the boiler. In addition - he claims that other builders must have moved the flue so it became wonky (bent at a junction and that's why water is accumulating and spits at intervals) I don't believe this would be the case as I expect the boiler flue to be clipped to timbers (flu runs in a ceiling void with access panels on every junction) clipped to timbers with no room to maneuver.
I called gas safe asking for advice but they didn't help.
Can somebody please tell me where I can find regulations regarding installation of copper pipes in voids. Where I can find information regarding flue installation (ie should it be tight or have room to move). I need to find some legal document like BS standards where all this can be specified and I can make a case with the plumber. Any information would be very much appreciated
thanks dee
thanks dee
