View the thread, titled "Indirect Hot Water Cylinder" which is posted in Bathroom Advice on UK Plumbers Forums.
Poynton Plumber
i have a client with a vented indirect hot water cylinder.
below the gate valve on the cold feed from the header tank, is a tee which is the cold feed to shower pump for the shower mixer.
can anyone tell me if this acceptable practice?
i have read that it wouldn't be allowed on a direct hot water cylinder.
Hi. Amongst other thing it will reduce the available head that is responsible to deliver the hot water to mixer / taps. Plus the cylinder could, if gate valve were to be turned off or cistern emptied and pump was drawing water. Be drained, which if being heated via a immersion heater, create a dangerous situation. Its far from good practice.
Reply to the thread, titled "Indirect Hot Water Cylinder" which is posted in Bathroom Advice on Plumbers Forums.
