View the thread, titled "Intec 34c hot water pressure low but boiler isn't." which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi everyone,
I've got a strange one. My boiler (intec 34c combi) has good pressure (high end of green).
When I open a hot water tap, the boiler fires up fine but it's just a trickle that comes out the tap. The water does get really hot though. My boiler is placed over an alpha flowsmart 50 if that's got anything to do with it.
Good evening Abliss,
You’re confusing the pressure required for your heating and hot water to be delivered by the boiler with your incoming water pressure. What’s the cold like? Has any work on the water main been carried out in the area?
Cold water supply is as strong as ever. No difference in the pressure there.
It’s possibly the cold inlet side the hot water, or a failure in the store.
Is it all taps? Yes?
Then there’s a restriction between the cold where it splits from the cold mains to go into the boiler and the hot out.
Could be a filter or plate heat exchanger.
Yeah it's all the taps including showers. I was reading on how it works and there's a blending valve which takes the hot from the flowsmart tank and mixes it with cold. Possibly there?
I'm not sure how my system works, if it's possible to get hot water directly from the boiler, or if it only allows hot water to come from this tank which is fed hot water by the boiler.
It's working OK now.
I had a dream last night and it was a couple of levers that got knocked. So looked into the boiler again this morning and noticed a small white box with a small slider on it. Moved it, and now pressure is normal. In the picture there's a thin metal lever/slider which is at the top position, well that was about 1cm down. Pushed it all the way up, and now all is good.
Scared to move it incase I make it worse haha.
Actually, this was just a coincidence. Not sure what that lever does. Back to low pressure.
Looks like a zone valve, it allows hot water water to heat cold tank water.
Sorry, I didn’t realise you had a tank, thought it was a combi, so disregard what I said about plate heat exchangers.
Yeah, I googled it and it's what you say. It's a Danfoss HPA2, which is a 2 port valve actuater. I don't know if this could be part of the problem or not though. I initially thought the blender valve might have something to do with it but I think that just mixes cold water and the hot water at a particular setting (currently set to 1).
Attached is my boiler set up
How does the 2 port valve work? When does it activate the actuator and open/close the valve? Does it communicate with the boiler thermostat or the heating control thermostat?
I seemed to have resolved it. There are two modes on my boiler; Summer or winter. I switched the boiler to summer mode and the hot water pressure seems to have come back to normal.
Reply to the thread, titled "Intec 34c hot water pressure low but boiler isn't." which is posted in Boiler Advice Forum on Plumbers Forums.
Thread starter
Joined
Location
United kingdom
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
Boiler Advice Forum
Start date
Last reply date
Abliss,
Abliss,
