F
FeelingCold
Good morning.
Firstly, thanks to the advice so many of you have provided over the years.
I'm in the final stages of renovation and I have specific questions relating to the venting of our kitchen waste water. Please see the attached pdf for my attempt at a plumbing diagram.
We have a dedicated 110 underground waste pipe to which only the dishwasher and sink will be plumbed.
Issues:
1. It is not possible to vent naturally from this area.
2. The 110 waste from kitchen is 5m to the join of the main waste drain, which is a further 3m to the main vent stack
2. the "riser" of the 110 waste is positioned in the wrong place in the kitchen..(don't ask.)
3. There is only a 50 mm void behind kitchen cabinets/sink and therefore cannot have a 110mm Durgo.
4. Void can probably be increased by 10/15 mm by chasing out plaster/render; but not further into the party wall.
Proposal:
I am proposing to use a reducer from 110 to 40 at a level near the floor (cabinets have 150mm vertical clearance).
Plum sink/dishwasher into the 40 drain and using either a 32 or 56 Durgo to balance the system. The diagram of the kitchen sink in the pdf probably better shows what I'm trying to say.
Questions:
Will a small diameter (32/56) Durgo work correctly with 110mm waste drain?
Would this proposed configuration be legal?
Is there a better solution?
My architect says that he has only ever fitted a 110 Durgo to 110 drain in the past.
Thanks in advance.
Andy
Obviously I'm looking at your drawing of the set up.
From what I can make out on that drawing it doesn't need a vent. I may be missing something?
Why do you want to vent that particular section?
Reactions: FeelingCold
Wow that was quick! Thanks.
I just assumed that this spur line would need a vent to balance it to ensure the suction didn't empty the P trap.
Neither 40mm from the Sink or washer would be able to create enough suction to empty the other trap in a 110mm pipe.
