Your boiler is not your problem. You need help with other underlying factors in your property
Can I ask why you would be entitled to a more efficient boiler than the one you currently have?
Yes I know that but I can't seem to figure it out. It's got cavity wall insulation, new windows and doors. Is it as simple as radiators as these are at least 25 years old.
It's a larger property isn't it ???
Yes but not massively and the plumber I had in is in a 3 bedroom up and downstairs and bigger than my house £46 a month. My sister is in an even bigger house than that with 4 bedrooms 2 toilets etc. Bath every day for the youngest shower for the other 3 2 adults 2 kids £60 a month. So it can't be that or can it?
I have replied several times to this person even give them a rough breakdown on what they will save & how long it will take to recoup the cost of replacing the boiler, But they seem determined to spend out on replacing a boiler thinking its going to save them money on gas in a property that's not even there's, Told them the heating is-not there problem but don't want to listen, So if it makes you feel happy go ahead and spend your money on a new boiler, I'm sure the council would like all there tenants to do the same, it would save them a fortune
You have me wrong I like to be double sure before I start a fight. And it is a fight. That's all and I am more than sure now sorry if you feel unvalued but you are well and truly valued my friend.
A fight for what? A new boiler free of charge when there's nothing wrong with yours? I don't really understand the point of this.
Reactions: 2 people
I maintain the problem is in your house and is not the boiler To be honest I would go back to what Tamz said and actually get some people in to assess your property for its heat and energy efficiency.
A fight for anything off them no not a boiler, but plumber did say that these type of systems were fitted when the back boiler was behind the fire. And are at least 25 years old even the energy company is bamboozled with the amount of units I used over the year and want £140 to test the meter. As they think the meter maybe at fault.
I maintain the problem is in your house and is not the boiler To be honest I would go back to what time is sai to be honest I would go back to what Tamz said and actually get some people in to assess your property for its heat and energy efficiency.
How do I get people into access it. What organisation?
I am downstairs now
I've just had a re-read for any clues...although your old flat was smaller was it on a first or second floor above and below other flats whereas now you're on the ground? It can make quite a difference in overall temperature and amount of heat required.
For a proper analysis you need to examine exactly how many units you are using and at what rate. Are you paying a different tariff for your gas because you are in debt? Besides the fact that your new flat is larger do you have any old bills from the old place to make a proper comparision and have you asked your immediate neighbour what they pay because if it's a relatively new gas meter chances are it is okay.
Are you housing association or through the council I don't understand how it works in Scotland im afraid that would be my first port of call tell them you have a problem although I just don't understand what you expect them to do. I realise there is a difference in cost to you but I have to say it's not 100% clear exactly what you are trying to achieve now
Also if the meter is up the swanny then they surely can't charge you for that as that's their property
It was second floor mate, I know what you are getting at but that doesn't account for my sisters mum's and cousins being up and downstairs and you know what woman are like with their heating. If I had a mrs with me could you imagine the bills!!
No I haven't to pay for the test but I don't think they will say it will be wrong they said it's took away to a site stripped apart and not usable again. Doubt they will give me credit for the bills I have been paying. That was never mentioned.
You said they want £140 to test the meter?
Is your sister on the same tariff cos there's no point comparing what you pay to her if you're not and a first or second floor flat is generally warmer than one on the ground floor for obvious reasons.
Haven't read all the posts but you've already got a condensing boiler, upgrading that wouldn't make much difference.
Older radiators contain a lot if water which needs more energy to heat up - this could be your issue.
Modern, efficient radiators hold a low water content making them heat up quicker and more efficient.
Plus there are other differences between your old and new property, insulation, Windows etc.
And then there is the tariff that your on from you gas supplier, is it the same one as before or have you just been on a standard one.
