Is it really cheaper for me to have central heating on all day than a gas fire?
View the thread, titled "Is it really cheaper for me to have central heating on all day than a gas fire?" which is posted in Central Heating Forum on UK Plumbers Forums.
With a hundred posts and no resolution we all need medication.
I am dissapointed in the Joke you make of medicine. I am on numerous medications for my conditions and you're going to get a result tonight. And tomorrow night aswell. Yes I admit it took a while to get it through to me about the Boiler but you have no idea of the fighting it takes to get things done and that is why I wanted to be more than sure that it wasn't a new boiler I needed as once the fighting starts I can't change my mind and say oh I want a new boiler if it was just radiators I was going to fight for, for example. and I can only apologise for that. But again I can't thank everyone enough for putting up with me for that and I just bloody remembered Christmas is nearly here so I can't do the test with the meter. Then again I might not have to. I might not have to fight for anything and to me that is well worth all this toing and froing as stress makes 2 of my major conditions a hell of a lot worse so please hang in there with me until tonight. And for the gas fire test tomorrow. And that's it done and dusted I now know I don't need a new boiler which I wasn't completely sure and radiators migh help a bit. To which I did not know any of so it's not been unfruitful to me quite the oposite and again I am sorry and thank you all for hhanging in there with me. And I mean that from the bottom of my heart!
In the hall mate not sweating roasting but very warm as Living Room radiator I was told to keep it at full. the rest at 2.
If your room stat is in the hall, then I would think it advisable to turn the radiator in the living rooms thermostatic valve (if you have one) to a sensible setting of about number 4.
Your room stat in the hall won't control the living room temperature accurately
I am going to keep it at full mate for the remainder of this test. Thanks again buddy.
Warm is just fine, knock the rad thermostat to 4 or 3 or whatever temp is comfortable without being too hot. What temp do have the hall thermostat and what is the point of "testing" your system at an unrealistically high temp?
I am testing at 21 degrees Celsius as that's what I use mate. At my dinner be back asap.
No point really. No thermostatic radiator valve should be much above number 4. That's going to give a room temperature of approx 24 degrees. If you turn it to number 5 setting the temperature will be about 29 degrees if you want a sauna.
Sounds like he has a programmable room stat, says he cant understand why it turns off, if he cant understand how it works he may be better to get it replaced with a basic RF unit on a stand so he can move it around with him.
Yes But I am better keeping it at that just now. the plumber told me 28. Once I have done the test I will put it down to 4 mate.
No I only know the basics of the thermostat. So yes maybe but I won't get it as they won't give me an extra one for my Bedroom to use when I can't walk. I have been told to use my electric blanket. So no way will I get it.
Setting 18 degree's for a hall thermostat is plenty, set your rad stat to 3 or 4. You'll probably find that's where your extra £20 a month has been going.
Heating controls - five money-saving tips - Creating an energy saving home - Which? Energy
Now that would be a result it's a danfoss wireless heating control and is only set to come on above 20 but I must have done something as when I turn it on now it comes on at 20 sometimes. Going to have a look on youtube to see if I can get it on my own. Failing that I will be calling for a heating engineer. And the last one I had didn't have a clue either
You obviously have internet else I wouldn't suggest this: you may find you can download instructions for your thermostat online if you put in the make and model number and do a bit of hunting.
Yes I do mate and I am off to hunt.
Yes I do mate and I am off to hunt. It's danfoss tp50001 I think that's the last model mentioned TP5001+RF
Stuff what people tell you to set your stat at! Your perception of warmth is different to mine or anybody else's.
For example. I like a cool house, Mrs Croppie doesn't.
Going by what you've said on here I would contact Scottish Power if I were you. They should be only too pleased to help you. If that gets you nowhere get on to environmental health.
1709 is the meter reading at 9:32pm, thanks everyone off to bed my guts are killing me. Oh, I get a sleep tonight. There's one major thing I forgot about my old house. And it is that it did not have a thermostat just a control, with on twice on all day and on. So I don’t know what the temperature was. I just had on twice a day setting and put it on and off whenever I was cold it had 24 hour clock on it, that revolved. So I don’t know if you guys would know what temperature that would be set at!
With no room stat the temperature is set by the boiler, if it was on twice a day rather than all day as your current system is that'll go a long way to explaining the discrepancy in gas usage from your old place.
Once you've got to grips with the hall stat set it at 18 to begin with and set your rad stats as you require them not what you think they should be. As you admitted you were boiling with TRV set on max therefore try a lower setting.
Yes I could only set it to warm house up in the morning and evening and just used it whenever I wanted in between and after those time mate. I have used 277 units if I am correct today then 1706 to 1709?
You've used about 3 cubic metres of gas today boiling your butt off, that equates to approx 34kw/h. You can work out from your bill what that is per day.
I think we've worked out why your usage is as high as it is haven't we?
Yes I think everything is OK. Thank God I don't have to fight anymore. You would think that it was coming out there own pocket, the council inspectors that is. I am so tired fighting them. Just got gas Fire to do tomorrow. And then it will be a couple of days in my thermals when they arrive to account for the wastage. But it was worth it as stress makes my conditions worsen and I thank you all from the bottom of my heart for bearing with me. Thanks again.
Do I have to run my gas fire the whole day. Can I not just calculate by the hour?
Reply to the thread, titled "Is it really cheaper for me to have central heating on all day than a gas fire?" which is posted in Central Heating Forum on Plumbers Forums.
hollyoaks777,
Dotty,
