In my van for stock I carry the following.
Stock
Box of fibre washers
15,22mm solder,compression & pushfit couplings
Flexi Hoses
Toilet syphons Lever & push button
Fluid master bottom/side entry
Donut washers & Brackets
Tap Revivers Basin & Bath
Assortment of 32/40mm Solvent weld fittings Buy Pipe to order, gets dirty otherwise. & A few Compression
WC Fittings and Flush Handles
Drain Clearing Chemicals
Bag Cement
Files
Sealants
Ball Float Valves Part 2
Trv & Rad Valve
Wastes Assemblys & a Few Traps
Fixings and Plugs
LSX,PTFE,HEMP,Gas Seal
Jet Machine, Rods,Snake
Plunger, Flush Gun
Assortment Cable Fuses
Screwdrivers
Flux
Steel wool & Abrasive Strips
Greases
Masking Tape
Insulation Tapes
Immersions 11 & 22
Tools
Circular Saw
Jigsaw
2 Cordless Drills 4 Batts
1 SDS Drill
1 Electric Plane
1 Grinder
2 Sanders 1 big 1 Little
1 Belt Sander
1 Foot pump (Pressure Testing)
1 Pressure Gauge
Jaw droppers Basin & Bath (Very Good)
Crowsfoot
Water Pump Pliers
Drill Bits
Core Drills Bits
Stilsons
Assortment Spanners
Ratchet
Hand Saws
Pipe Slicers Copper & Plastic
Vice
Torches & Head Light, inc Batteries and inspection Lamp
Steps, Beer Crate
Spirit Levels
Pencils and Sharpener
Knifes
Board Lifter, Crow Bar
Good Chisels & Old Ones, Bolsters
Allen Keys
Blow Torch and Spare Gas Mapp & Propane
Dust Sheet (Plenty)
Clear flexible tube, good for draining water out prior to soldering
Loads of Containers to collect drips & spills
Wipes & disinfectant
First Aid Kit
Goggles High Vis Vest
Coat And Wellies Gloves inc Disposable
Pipe Benders 15,22, and Microbore
Plastic Pipe Ratchet
Trowels and Floats
Dust Masks
Hoses, Funnels
Cement Bucket
Water Regs and Brochures
Reciept Pads and Stationary
I am sure I forgotten something
2 Fire extinguishers 1 in van one in tool box 😀
Poulsane,
I know what you're saying, but you're probably a better driver than me. I had a Mercedes Vito a few years ago from new (non plumbing related) and I was always bashing and scraping it in tight spaces etc. Once in the dark I creased the side in on a small unseen wall and caused £££'s worth of damage. 😱
I'd love a kind of TARDIS van though!!! 🙂
I never listed my equipment, no time at the moment though.
You need to list your tools and stock in the event of theft, and its good for your accounts regarding stock levels, as well as large tools for depreciation. Oh and forgot wallett of insurance doc, mot, PLI insurance and COSHH data for chemicals and sealants.
In my van I Have
a screw driver with multipul heads and one that shines up if you are working on sumfig your not spost to
Two pairs of grips
Copy of sun newspaper dated march 14 2007,just read it every day,they print same stories anyway
17 unpaid parking tickets and 4 cut off wheel clamps
and whats this on the floor.Avent seen one of these before,ahhh yes,I remenber,its an old tax disc
Sometime put me jetting machine in,well actualy its a hoover but makes the right sound
See you around but you will have to be quick
ps
And Winston a wallets for cash mate not all that paper junk you mentioned
pps
Hope you get the shower sorted out OK 🙂
