duffsparky
I've started a discussion at- http://www.ukplumbersforums.co.uk/plumbing-forum/21292-shower-pipe-sizes.html#post155539 - regarding shower pipe sizes and fittings, I didn't realise there is a seperate Fittings & Pipe forum.
Any way I want to connect a 15mm x 15mm full bore isolating valve to the 1/2" male connections on my shower mixer valve. I need to keep the assembly as short as possible and don't have sufficient room to connect the two together as normal. I want to know if I could get away with fitting a 1/2" x 1/2" female/female socket, see middle picture fig 2 below
fig1 isolating valve.jpeg fig 2conex 1-2 female female straight coupler.jpeg fig 31-2 bsp male adapter2.JPG
Obviously have to remove the 15mm conpression nut and olive and fit a seal, possibly and "O" ring or fibre washer, between the valve and the 1/2" male tap tail.
I've looked for isovalves that are 15mm X 1/2" but they all seem to be small bore and I want to use full bore. If I put the valves elsewhere there will be a problem accessing them. I've looked at using 15mm X 1/2" adapter but they are too long, I've also looked at using 22mm X 3/4" isovalves fitted with 3/4" x 1/2" reducers but again I think they'll be too long.
As an alternative I've found this fitting 15mm O/D tail x 1/2" BSP, made by JG in there Speedfit range, see photo fig4 below
Here's what I'm trying to acheive, see fig5. By the way the left hand pipe in not in its correct location
Any advice would be much appreciated.
as above, I would not want to put iso valves there. Put them in the loft for easy access, plus if they leak, you can visually see it.
Unless I put the valves under the floor or in the walls they'll have to go under the shelf which sits in the corner on top of the corner mounting bracket. There is sufficient space to access the valves and if they leak the water will drip into the shower tray. I just need a suitable way of joining the valves, without using the olive and compression nut on one end, to the 1/2" male inlet of the mixer valve.
Cheers
wont a ballafix swivel fit ?
Length wise that type would be ideal, however, the only ones I can find are all small bore and I want full bore. Anyway I have found a solution and pressure tested it and all seems OK.
Thank you to all who have contributed.
I doubt duff sparky will be back to tell you, however the right way to do it is in the comments above, as a side note, I would have done away with those horrible offset connectors and brought the copper out at 150 centres into shower fixings.
Reactions: 3 people
Sadly, shortly after my last post, divorce rose its ugly head and I didn't get to finish the installation. I can't remember what my solution was and the above suggestions where not ideal because they significantly increased the pipe runs in order to keep them out of sight, which was something I was trying to avoid. Sorry I can't help.
