Keston boilers
View the thread, titled "Keston boilers" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Millsy 82
The company I work for have just got a new contract and the few I have been out to over the past week or so have Kestons fitted is there any common problems with them that I should be aware of apart from being a pile of poo and needs ripping off the wall.
You already know the answer 😉
Burner gaskets blow, causing fusible link to fail, if you're luck or distorts hes if not, always replace if servicing, and worth keeping a couple to hand if you're going to be seing a few of them.
Stupid black flue duct cracking
Dropping allen screws from casing!
etc.....
etc.....
Are the gaskets the same on all the models like vaillant or do I have to order in different ones for different models.
Reply to the thread, titled "Keston boilers" which is posted in Boiler Advice Forum on Plumbers Forums.
Millsy 82,
Roger Welton,
