phil76
Hi all. Just wanted to ask for some help as I'm stumped on this one...
So thought kitchen sink was blocked. Its new build and only moved in about 2 months ago... So I checked pipes under sink and all clear... Then ran a hose down the waste pipe under sink and checked to see it was coming out sewer. All fine. Ran water through all white pipework before connection to final downward grey wastepipe and it flows no problem. Connect white pipes to grey waste and hit problem. Really slow drainage again (i mean half hour to empty sink slow)
So after hours of banging my head of wall. I cut half inch of grey waste pipe so it was running level after u-bend into waste and not slightly uphill as previously. Also noticed that after u-bend on final straight stretch into waste the water level very low (using torch behind pipe), no matter how full sink.
So drilled a small hole in the straight section to grey waste and p****ssst, air flying out... and sink draining better... If I block hole again it airlocks. No idea why.
Can anyone help, as I don't think drilling holes in pipework should be the answer.. Also Sewers all look clear, but some toilet niceties are lying a little higher, due to heavy rain I think.
Have stuck a crude diagram on to help
MAny thanks
MAny thanks
