URGENT Leaking lpg continental rf6030 4 cylinder manifold
View the thread, titled "Leaking lpg continental rf6030 4 cylinder manifold" which is posted in Gas Engineers Forum on UK Plumbers Forums.
Hi all,
I have an lpg setup that was fitted November 2018. We have 4 x 47kg cylinders connected to a continental rf6030 auto changeover manifold.
This evening I swapped over a pigtail on one of our reserve cylinders that had been damaged by a rat having a midnight feast on it. When I undid the w20 fitting from the manifold tee connector I was worried I had disturbed the tee undoing the nut. So once I had connected the pigtail I checked all the connections with soapy water and then let a little gas into the line. Low and behold the tee started blowing bubbles in the middle where the two parts screw together to make the tee. This I presume is easily fixable with some gas joint compound and a hex key to tighten the joint. Being cautious I covered all connections with the soapy liquid, the bigger worry is that the threaded connector that is screwed directly into the body of the manifold is causing very fine bubbles at the join. It looks like these connectors come pre fitted to the manifold but there is a 22mm spanner fitting around its outside. Is this something a plummer can undo, add joint compound and re tighten or are we going to have to get a new manifold? I am attaching a photo to better demonstrate what I mean. The reserve cylinders are both turned off now so there is no extra leaking gas. I would like to have an idea of what’s possible/needed before phoning up plumbers.
Many thanks for your time, your opinions would be greatly appreciated.
Going by the photo I would say the biggest concern is the leak on the pipe (to the left), the other leak nearest the manifold might just need re making.
Thanks for the reply rpm. I’m only more worried about the leak at the manifold incase it means we need a new manifold, the tee is at least a relatively cheap part. In fact after I took the photo I gave the tee a bit of a tighten which almost fully stopped the leak at that point. Hopefully with some thread seal it will be as good as new. My main worry was whether it was physically possible and acceptable to loosen the thread sticking out of the manifold and reseal it as it seems to come factory fitted. Sound like you think this might be possible?
The joint at the manifold has a fitting with hexagon flats for a spanner and being different metals there is a joint there however I don't know how easy it is too over tighten and split the manifold!
Re the pipe, I thought it was fractured going by the line.
I don't do gas and don't like advising on it, please get someone in to do the job.
it looks like a flare djoint so not a diy job need to get LPG registered engineer in to do repairs
Reply to the thread, titled "Leaking lpg continental rf6030 4 cylinder manifold" which is posted in Gas Engineers Forum on Plumbers Forums.
Njwwright,
rpm,
