Leaky back screw male to female 1/2 junction for shower outflow.
View the thread, titled "Leaky back screw male to female 1/2 junction for shower outflow." which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Hi there
I connected a new shower wand which has a chrome outlet back into a 4" inch thin wide wall and comes out to a 1/2 inch male. I put a 1/2 inch female screw (90-degree bend to a 15mm compression join) over it and tightened it and used PTFE tap ( alot) to seal but the female fitting butts up against the retaining screw and drips when I did the pressure testing of the circuit with a pipe stop end at the end of the shower fitting..
Should I just plaster it with more PTFE tape or find another fitting which is thinner, if there is one? I have looked for a thin female 1/2 but they seem very standard.
Any ideas would be great?
Best
Matt
Did the old one drip, is the female fitting perhaps split open. If it is a slow drip then perhaps a light smear of LSX over the tape might help. But not if the fitting is split of course.
Hi
This is a new install with new components which i need to tile over so like your idea about LSK but rather get it right first time without leaks if possible.
Reply to the thread, titled "Leaky back screw male to female 1/2 junction for shower outflow." which is posted in Showers and Wetrooms Advice on Plumbers Forums.
diy_massacre,
Ben-gee,
