PH should be 0. Do you mean 7? I assume you mean you need the pump to make getting the correct quantity of solar fluid to water ratio easy?
This is really interesting.You are correct - PH 7. - apologies!!
The difficulty I have experienced is that any residual left in after flushing makes getting the correct PH time consuming - often needing further flushing. This is a bigger problem in hard water areas
Why does it need flushing mine has the same water & special antifreeze mix for the last 10 years. It has a filler from mains water via a double check valve to top up if necessary but in all honesty has never needed doing . Original antifreeze was pumped in via small hand pump before water from mains supply.
out of pure professional curiosity whose solar fluid have you used ? assuming its equvalent to Sentinal R100Why does it need flushing mine has the same water & special antifreeze mix for the last 10 years. It has a filler from mains water via a double check valve to top up if necessary but in all honesty has never needed doing . Original antifreeze was pumped in via small hand pump before water from mains supply.
They all put fancy colours in to solar fluid toI think it came from someone called secon solar, bright pink. It said long life, but that's about all I remember. Ta Chris
Out of curiosity, why if everything is working fine? All the pipework is stainless steel apart from the coil & the panels heat exchanger. The pump packed up a couple of years ago and the fluid mix was nice & clear that came out of the pump.
Anybody would be a fool not toDo you change the oil in your car ?
I was thinking a dump radiator is probably a really good idea.I think from reading various articles that the thing that makes the fluid break down is allowing it to boil. On mine when the temperature in the cylinder reaches 85C the solar heat is diverted to a dump radiator. I think in the whole time it's been installed it's only done it a couple of times as its quite a big cylinder & people in the house tend to use the hot water with showers etc.
We are learning alot about solar at present, in fact I am non exec dir of a Solar ThermalI was thinking a dump radiator is probably a really good idea.
Conventional thinking is it's better to heat a lot of water to a low temperature and then use gas to top-up than heat a little water and risk overheat, but that line of thought means that your solar will be insufficient even on the hottest days.
I must say I do like the idea of a solar system that dumps the heat on very hot days and is sufficient without gas top-up more of the year.
There are a few units like this one, and clever people with pv time their hot water usage for lunchtime , so its back to cylinders out with the combi if you have space...mind you pre warming mains cold before the combi can save loads of uplift energy...there is a few latents going thro on this at the moment...would not know whom tho !Back to solar PV. I have this also, I bought a bit of electronics from someone called Optimersion (I think they have gone bust) there are others around. It detects what would go back into the grid & diverts it to an immersion heater, so on average sun I get a reasonable amount of hot water 50- 55C ish, hot enough for most things. On the rare days as I said previously it can go up to 85C at which point the dump radiator kicks in, not that it hardly ever does. There is a thermostatic valve on the hot water outlet that limits the output water to 60C so it doesn't scald people.
