M
M.Joshi
"fun"-fan ( spelling issue )
Oh, I see! However, mbar is generally associated with gas pressures not fan rotation?
What about 'flux switch'?
M joshi SGI gave you a price and you didn't take it you got another company in for less money and you still have problems
Do you really expect him to now tell you the problem for free????
Don't see any comment as cocky apart from yours this is a gas boiler that legally you can not work on so why should you be told what the problem may be I'm sorry you didn't get a decent plumber in on the first place but if you want it sorted once and for all I'd do a bit of apologising to SGI
Was I right?
Thanks for everyone's replies so far.
We've just had a service on the boiler today - the D2 TRVs have been ordered.
I am a bit concerned that the service wasn't done properly. We paid £60 +VAT and this is all that was carried out:
Remove cover
Check gas pressure / boiler output
Clean out condensate trap
Visually inspect heat exchanger from outside
I mentioned that the hot water was extremely hot at the time of booking the service but, they were not able to find out what was causing this? They only identified that the hot water pressure was lower than the cold water pressure, the hot water was cloudy and that a filter? may be blocked in the boiler.
I thought that during a service the boiler should be stripped down and the heat exchanger inspected for any corrosion. Does £60 +VAT seem expensive for this service (NW London)?
They didn't carry out a flue combustion analysis - when I asked why not, they said it wasn't required on a standard service. Their meter was away for cal. but they could do this at a later date!
So, is the above list all that is required for a full service?
I was always taught that the gas rate just shows you that its using the correct amount of gas not that its burning correctly.
On these boilers I do
1.Flue analysis on high flame (case off) adjust as needed
2.Flue analysis on low flame (case off) adjust as needed
3.Gas rate
4.Flue analysis on both high and low flame case on if a seal has gone in the boiler or flue the co/co2 will start to rise. you do tend to find quite alot of problems Ive had split flues, split seals, flues not put together correctly etc.
I might just be being fussy but better to cover yourself
