Lukewarm water problem with Veissmann v 50 gas boiler
View the thread, titled "Lukewarm water problem with Veissmann v 50 gas boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi all, thanks for adding me.
My Veissmann v50 combi gas boiler has recently started to supply only lukewarm water to the bathroom above it. This is about 3 metres away, so quite a short pipe run. It supplies hot water fine to the kitchen taps, which are about 1 metre away. It also supplies very hot water to the central heating system, with no problems. The boiler is about 6 years old. I have made sure that the boiler pressure is okay. Can anyone suggest a solution?
bath flow is normally faster flow, not pressure don"t get mixed up like a lot of folk do.
try slowing the flow down , and see if that sorts it
Ok thanks. I meant that the boiler pressure is okay, I realise that this isn't the same as the pressure to the taps. A heating engineer has said that I need a new boiler, what do you think?
Reply to the thread, titled "Lukewarm water problem with Veissmann v 50 gas boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
PaulGra,
PaulGra,
