View the thread, titled "Macerator toilet blocked! How do i remove waste/water?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi
The toliet pipes attched to the Macerator started to leak water yesterday when flushed. The macerator made a longer than noirmal whirring noise too. None of the waters been flushed and waste has come into the bowl with water, right to the top.
I've ordered a water pump vacuum from amazon today. Has anybody had similar issues and does anyone know if the water and waste can be vacuumed out with these pumps?
The quotes for this process from companies were too expensive for me.
I'm thinking of ordering a new macerator after letting the toilet dry.
i've never done this before,so, i'm a bit nervous. I'm guessing i don't have to turn anything off etc when sucking the water out with the vacueme?
Thanks for any help
Bale out the water in the pan then the water inside the macerator will fall to the height of the pan outlet spigot.
Which pipe is leaking, inlet or outlet. Can you post a picture?
Yes it can be vaccumed out as long as bleach hasnt been poured down the pan.
The definition of a shitty job.
Did someone flush a wetwipe?
Expect it to get messy, I hope you've got a strong stomach.
Good luck
Don't need the wet vac (nice but not essential at all). I'd prob cancel that and save cash for the macerator if required.
As you are working on the macerator I would electrically isolate it first, and physically disconnect the electrics if you start taking it to bits. I've seen bad installations with electric cables on bathroom floors . . .
Just bale the loo out as low as you can, then put a shallow disposable container (e.g. cut up a square 5L plastic bottle) under the join, and after removing tank etc pull the pan off the macerator. You can then gently lean the loo to empty the residual.
I've little macerator experience, but I remember one on site that blocked after years of good service. It was possible I think to open that, which revealed it was full of grit. Go figure as they say. It just needed emptying. However yours you say is leaking.
Good luck, and please get help on the electrics if unsure. It will be satisfying to fix and minimise the cash spend in these difficult times.
Cheers,
Roy (Amateur plumber)
Not a pleasant job by any means a good quality wet vac is a must my every day one is a Draper will suck up most things and easy clean up. Kop
Bailing out the loo is not something I would even consider, buy the wet vac and stay smelling sweet, better yet is re-plumb without the macerator, but sometimes not possible, I would even consider putting the loo in a different room, but would do everything I could to get rid of the macerator.
Reply to the thread, titled "Macerator toilet blocked! How do i remove waste/water?" which is posted in Boiler Advice Forum on Plumbers Forums.
