Magnacleanse flushing vs. other systems
View the thread, titled "Magnacleanse flushing vs. other systems" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
M.Joshi
I've been advised by Adey that the Magnacleanse flushing system is suitable for all systems even ones with older pipework.
Can someone confirm if this is the case? Is the Magnacleanse less harsher than the likes of Kamco and Fernox flushing systems?
I can't seem to easily find anyone in NW-London who does the Adey Magnacleanse flush though!
The magnacleanse system does not use a pump. It relies on the system pump. You fit a magnaclean on the return as close to the boiler as possible and then connect the magnacleanse unit to the magnaclean isolating valves. You then run the system and isolate all the rads bar one and use the vibraclean on the one radiator to loosen any mmuck and sludge in the rad. This is repeated on every radiator in the system.
I've found it to be very effective.
sludge by Mike Jackson1, on Flickr
Looks good, I am now considering this over the Kamco powerflusher. Whats the going price for the magnacleanse new?
So far I've been more than happy with the results I've got. The fact that I walk away and leave a magnaclean continuing to protect the boiler and I can still do the whole thing cheaper than a powerflush.
Magnacleanse works well and you leave Magnaclean connected to the system for future protection as Mike said. However I would just pointed out one thing you could find difficult and that is system with small size pipework which you could find little difficult to clean so it could take more time than using powerflush machine with reversing in flow. But adding acid should do the trick if you get stuck 😉 I've got myself one as personally like its results. Cheapest I've found incl vibrahead was £400 inc VAT.
Just treated myself to a Magnacleanse unit and was wondering what SDS drill you use for the vibraclean, I guess a cordless would be more convenient.
ETA: plumbase are doing them for £360 including a magnaclean mini at the moment
i'd imagine you can use any sds drill with hammer action, my battery sds is just as powerful as my 240v
Excellent, I was looking at the Hitachi, good to hear some feedback about it. I have the 6.5kg Hitachi and had no problems with it (though may be a bit on the large side for this application!)
24v sds i have, got it for £200 reduced from £300. Its not the best but its served me well, so far...
Here's a thought - could you use one of those small (mouse) sanders instead to agitate the magnetite in the radiator? Replace the sandpaper with a soft pad.
The vibraclean is a lot more effective than a rubber mallet though. First job I used it on was because the rubber mallet trick had failed completely. I had all rads in the house cold over 2/3 of their surface area. Taking them out and flushing outside was not a good solution as none were under 2.4m in length and there were 2 3600 x 600 double panel rads. 2 men would have struggled with it empty but half full of sludge it was a non no.
Took me a while but I got every rad in the house hot from top to bottom with the vibraclean. A word of warning though, don't use one with a hang over.
I've got a 36v Bosch SDS that I use it with although any SDS with rotary stop will do the trick.
here is my input i have used my magnaclease with and with out a powerflush,
Reason with out is because plastic pipe etc, but for better results use with a powerflush machine amazing results, and the viba hammer works a treat, Am doing one tomorrow with the power flusher so i will out results up for you.
I did one on my mates system which was clear, and the magnets still picked up a wee bit of stuff,
If you need any information about them just ask
Pic with powerflusher
i use a second hand norstrum powerflushing machine along with my magnacleanse total cost £700.00 never had a problem and the magnacleanse is fantastic they dont half pull some muck especially when using the vibraclean i use an erbauer 24v sds. too be honest it's crap for drilling but good for using the vibraclean
I can agree with all the people rating the magnacleanse machine, I think its realy good, well impressed with it, I paid 420 icluding vibraclean and attatchment to magnaclean of auction site.
Only thing I dont like is its a pig to clean the sludge off the magnets when done as they are so strong, wondering why they dont make plastic covers to go over the magnets for easy cleaning like the normal magnaclean filters. Perhaps it effects the performance.
julesverne funny thats what i have been using the best results is using heat either from the boiler of norstorm heater,
MY pal thought it would be cool to touch each magnet (donut) sludge everywhere, bit of a bugger to clean but works tho
In the pictures above I just put a pair of disposable gloves on and ran my hand down the shaft (ooh er misses) and pushed the sludge off. Leaves a wee bit on but gets rid of most of it.
Reply to the thread, titled "Magnacleanse flushing vs. other systems" which is posted in UK Plumbers Forums on Plumbers Forums.
M.Joshi,
Heating-eng,
