J
jonnyg
I was wondering if i could get a bit of advice, I've got a Main 30 elite combi and it's not switch over to the central heating from the hot water and after reading a few threads on here i came to the conclusion that it could be the diverter valve so decided to get a repair kit off ebay.....
I isolated the water/electrics and drained the combi and removed the valve which did look knackered and replaced with the new one. Repressurised etc but i've still got the same fault.
I can push the pin down manually on the diverter valve which then supplies hot water to the radiators so was wondering if it could be the motor that sits on top and is there anyway of testing.
Thanks in advance Jonny
This plumbing forum will not provide advice to anybody with regards to boiler repairs or any other form of gas plumbing without you first providing us with your Gas Safe Registration number in a thread - for very obvious reasons. If you're not qualified to touch gas, you should stay well clear of trying to!
