armyash
Subscribed
Oct 13, 2010
2,650
699
113
Kent
Hi guys
been sent to this property a few times
Their water heater keeps playing up, until today when ever i have been there it has been working fine. Today I got sent there and it would light for a few seconds then go off, relight then go off and so on. About 2 months ago we upgraded the gas pipe to 22mm and it had been fine.
Any experts here know what the problem could be? I'm thinking either a temp sensor is faulty or the gas valve needs adjusting
It was fine for 18 months then the problems started.
Is the pilot light going out Ash? If it is, it's the pilot injector. Undo the brass but in the centre, just inside the case. There's a brass injector in there, note which way up it is before you remove. Clean teeny weeny hole out with a strand of cable flex. Re assemble and gloat at your brilliance.
Reactions: 2 people
Reckon that could be it. Should be sent back tomorrow as can't leave them with HW probs over the weekend. Will update.
Reactions: 2 people
