Making the Perfect End Feed Solder Joint
View the thread, titled "Making the Perfect End Feed Solder Joint" which is posted in UK Plumbers Forums on UK Plumbers Forums.
...twas a recent job, couple had pipework re-routed round attic sides ready for conversion...local 'handyman' did it......about 4 kilo's of solder I reckon AND it had no less than three leaks...never seen so many couplings used before......crap job in every respect, but proves the point that visible solder and snots does not mean a solid joint....View attachment 9105
​theres a sparkie infestation there call rentokillaspark
Hahaha....are people really this thick?!?!
My first attempt at plumbing (about 30 years ago), Yorkshire joint, no flux, surprise surprise it leaked!!!
Never had a leak since.
Plumbing is OK, it's the bit dealing with bogs that I can't handle.
The amount of crap that goes down my drains living with 4 females I have to unblock the drain now and again, but someone else sh.... no no ...
The amount of crap that goes down my drains living with 4 females I have to unblock the drain now and again, but someone else's... no no ...
Funnily enough I'm the other way round. I can't deal with it if I know who it belongs to!
Being pipework boys, you should know your way around a lasses pipework and make it function correctly?
I love cats, got two (3) black furry beauties myself, but as a day to day job, mmmmmm, might be better off being a plumber 🙂
Can't do with ginger, but I'd quite happily work on min wage in a decent Scottish Malt distillery! 🙂
I love ginger especially irn bru but i like a bit cream soda too. That dandelion and burdock is not ginger. It's rotten.
No call for plumbers in the malt distilleries. They just lap up the leaks.
Translation
ginger = juice
We don't condone slagging the glow in the darks up here. You get used to it and quite handy for finding your **** :wink:
Never read so much information about how to solder a joint,
Fantastic,
1. cut out all copper in sight
2. replace with plastic
3. plastic joints
4. flexibles
When in a spot and have to use copper then buy the glue that joints them, now what is that called, system 3 can you help here?
Some more information on soldering, given the op wanted to work toward perfection:
Why Wet cloth and dry cloth?
The use of a dry cloth removes the excess flux 'before' you start soldering (most important tip)
The use of the wet cloth removes the flux residues after the joint has set, and you have finished soldering.
However, a note to those plumbers who insist on wiping around the joint after the solder has been applied, to make a neat looking 'wipe' mark.
This is a habit from the days of leaded solder when the plastic range of the solder made it such, that the solder was still mushy and could be worked for a few seconds after soldering - I too had this habit of wiping around the joint - but it is not needed.
Lead free solder has a different 'plastic range' and will set quickly. If you can wipe away lead free solder snots, then you have made the following actions that are just not required:
1. You have applied too much solder in the first instance risking waste of resources, time, money.
2. You have applied too much heat in order that lead free has plastic range which risks oxidising the joint.
3. You have risked 'cracking' the joint because you have touched it during its 'setting' stage.
If we wish to move our existing skills to those of mastery we sometimes need to recognise 'reasoned' scientific arguments. If people wipe around their joints and they have always done it, and had no problems, then they are masters of waste, and plug their ears when others advise - this is also an outcome of mastery, because we are capable of doing things the wrong way for years, but still achieve a desirable outcome - I am guilty of this too, but perhaps not for soldering!
.... Lead Free .... Cleaning Snots
Cheers , so if you can wipe a lead free .... you've done it wrong
and should not be prodding it while it sets
I only wipe once it has cooled slightly. My pet hate is to see green joints where the flux residue has been left on. Yack.
thanks to everyone who replied.
As well as advice on making the perfect solder joint. I have also learned about:
- cats
- unblocking toilets
- female plumbing
- activities of electricians
Amazing!!
thanks again everyone
- cats
- female plumbing
Amazing!!
Pleasure Tutto, we've a wealth of knowledge and information available to those who ask and those who dont!
- cats
jack russels normally fix them
you put it there you fix it
- female plumbing
cant be fixed,its got a mind of its own
​there all weird
parrots large grey chatty things always asking for grapes when all it wants is the finger holding the grape
Just use your flux brush to flick the droplet off, obviously you have to keep the flame on the joint until just before you're about to flick it. wire wool brushed back and forth parallel to the pipe also works...
Reply to the thread, titled "Making the Perfect End Feed Solder Joint" which is posted in UK Plumbers Forums on Plumbers Forums.
tuttogallo,
h2o plumbing,
