View the thread, titled "Making the Perfect End Feed Solder Joint" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Translation
ginger = juice
We don't condone slagging the glow in the darks up here. You get used to it and quite handy for finding your **** :wink:
Never read so much information about how to solder a joint,
Fantastic,
1. cut out all copper in sight
2. replace with plastic
3. plastic joints
4. flexibles
When in a spot and have to use copper then buy the glue that joints them, now what is that called, system 3 can you help here?
Some more information on soldering, given the op wanted to work toward perfection:
Why Wet cloth and dry cloth?
The use of a dry cloth removes the excess flux 'before' you start soldering (most important tip)
The use of the wet cloth removes the flux residues after the joint has set, and you have finished soldering.
However, a note to those plumbers who insist on wiping around the joint after the solder has been applied, to make a neat looking 'wipe' mark.
This is a habit from the days of leaded solder when the plastic range of the solder made it such, that the solder was still mushy and could be worked for a few seconds after soldering - I too had this habit of wiping around the joint - but it is not needed.
Lead free solder has a different 'plastic range' and will set quickly. If you can wipe away lead free solder snots, then you have made the following actions that are just not required:
1. You have applied too much solder in the first instance risking waste of resources, time, money.
2. You have applied too much heat in order that lead free has plastic range which risks oxidising the joint.
3. You have risked 'cracking' the joint because you have touched it during its 'setting' stage.
If we wish to move our existing skills to those of mastery we sometimes need to recognise 'reasoned' scientific arguments. If people wipe around their joints and they have always done it, and had no problems, then they are masters of waste, and plug their ears when others advise - this is also an outcome of mastery, because we are capable of doing things the wrong way for years, but still achieve a desirable outcome - I am guilty of this too, but perhaps not for soldering!
.... Lead Free .... Cleaning Snots
Cheers , so if you can wipe a lead free .... you've done it wrong
and should not be prodding it while it sets
I only wipe once it has cooled slightly. My pet hate is to see green joints where the flux residue has been left on. Yack.
thanks to everyone who replied.
As well as advice on making the perfect solder joint. I have also learned about:
- cats
- unblocking toilets
- female plumbing
- activities of electricians
Amazing!!
thanks again everyone
- cats
- female plumbing
Amazing!!
Pleasure Tutto, we've a wealth of knowledge and information available to those who ask and those who dont!
- cats
jack russels normally fix them
you put it there you fix it
- female plumbing
cant be fixed,its got a mind of its own
​there all weird
parrots large grey chatty things always asking for grapes when all it wants is the finger holding the grape
Just use your flux brush to flick the droplet off, obviously you have to keep the flame on the joint until just before you're about to flick it. wire wool brushed back and forth parallel to the pipe also works...
Reply to the thread, titled "Making the Perfect End Feed Solder Joint" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Thread Tags
tuttogallo,
h2o plumbing,
