Makita 18v sds
View the thread, titled "Makita 18v sds" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Millsy 82
Are they any good and do the batteries last long?
I want a cordless sds and ideally would like a 36v but can't really afford one.
All my 18v kit is a makita so I was wondering if it is worth buying.
Really I want it for when I'm doing rads etc so would only need to drill the occasional hole through for larger pipes when doing rads behind each other. I might just wait a few weeks/ months and get a 36v but they are quite a bit more.
Yeah this is mine.
Got the changeable chuck which is handy.
I worked with billy once and used his Milwaukee and I'd say that was marginally better but for the cost I'm more then pleased with mine. I did have to send it off once for a new trigger (free) but other then that it's been brilliant for the abuse I've given it
It will be fine for that kind of work
To be fair having a small and light SDS with no lead is handy. I think if you want a powerful SDS you can buy a mains one for a lot less than a powerful cordless.
for wacking up rads I have had a ebaouer (cant spell it) fm screwfix for 3 years and it does it fine for the price.
Mine was really good, I got it for the sds adapter / vibrator when power flushing...
It got pinched from the van tho 🙁 pretty thirsty on big stuff as to be expected, but would hang rads etc with ease all day!!!
I have a 21volt Hilti small SDS cordless drill for doing raw plugs. Body was only £129+vat
Great job, but that Makita is so cool looking!
I use the older 18v makita sds (not brushless) everyday for rads and pipe holes in masonry and concrete I think 26mm is largest I have drilled in masonry with a stsndard sds bit but I tend to step the drill sizes up to give it an easier time 8-10-16-24-26 etc. Even though it can be hungry its hardly a problem if you have enough batteries. There is always 1 charging or full and 3ah only take 20-30 minutes to full.
I have the makita in the above link, and use it all the time for rads and the like, have occasionally used it for larger, but prefer to use corded sds.
I have both 18v and 36v Makita cordless sds , 18v (bhr202) is brilliant , the 36v with both 36v batteries and twin battery adaptor (so for use two 18v batteries) cost a fortune and is no better than the 18v one in fact it's heavy, not much stronger, has a different charger and is pants! Don't bother just get a 18v and save yourself a fortune! I also prefer the old type 18v drill (bhr202) to the new brushless one, mines out lived my mates brushless one and had loads more hammer!
Just ordered a bare 18 v bhr 202, £125,used them before on heating contracts,and the 36 v model, the 36 is a heavy beast,but the 18v is light handy and quick,and seems to be better made than its big brother
Reply to the thread, titled "Makita 18v sds" which is posted in UK Plumbers Forums on Plumbers Forums.
Millsy 82,
ShaunCorbs,
