smtplumbing
Allright guys / Girls i am having am massive clear out of my garage as these items are just sitting here and i have got a massive stock in my own van and tbh i will never use these all as i just end up going to plumb centre and the customer pays for it.
I purchased the full lot from a plumbing place that was closing down in falkirk (went bust) i have only manage to sort out on2 pallet all ready may have more but below is what i defo have.
If i am not allowed this post please delete the post, As i am a new member here i am willing to post the stuff on ebay if needed where i have 100% percent feedback think about 228 odd.
I no what everything is worth and not after lot for these items i just want to start clearing out, so make offers single items or on the lot, i am will to post collect and maybe even deliver( eg lot sold or fair amount of items sold ) am based in falkirk scotland but work in edinburgh and i am willing to meet anyone if needed
Thanks steven Smt Plumbing and heating
Plumbing stuff
McAlpine stuff ALL BRAND NEW AND BAGGED
7x 1" 1/2 TO 1"1/4 straight insert reducers
4x 1" 1/4 Straights
2x 1" 1/2 s traps under bath
2x 1" 1/4 P traps
1x 1" 1/4 p trap extended
5x 1" 1/4 45o bends
2x 1" 1/2 Washing machine traps (p trap style)
1x 1" 1/4 straight trap
8x 1" 1/2 Straights
9x 1" 1/4 bottle traps
125x 1" 1/4 90o bends
33x 1" 1/2 TO 1"1/4 straight reducers
37 1" 1/2 45o bends
31x 1" 1/2 90o bends
79x 1" 1/2 Tees
41x 1" 1/2 S Traps
1x 3"1/2 pan connector
1x 4" pan connector
1x 4" flexy pan connector unbaged
15x 4" 20mm offset pan connectors
2x 4" Straight Pan connectors
1x Convertible syphon
9x Cooker Flex brand new still in packing
Compression Fittings All fittings have there nuts and olives
2x 15mm Tap Connectors
5x 15mm blank ends
12x 15mm tees
9x 15mm straights
25x 15mm bends
11x 22mm olives
1x 22mm tee
10 x 22mm tap connectors
6x 22mm bends
19x 22mm straight
well i no how much each fitting is worth, but tbh i just want to get rid of these so i will take offers
Are these end feed copper?
11x 22mm olives
1x 22mm tee
6x 22mm bends
19x 22mm straight
if they are I'll have em....
these are compression fittings. i started clearing more and found more topped up my boxes which are now over flowed and have 22mm yorky solders stuff and 22mm stop cocks
Plumbing stuff
4x 1" 1/4 Straights
2x 1" 1/4 P traps
5x 1" 1/4 45o bends
8x 1" 1/2 Straights
37 1" 1/2 45o bends
79x 1" 1/2 Tees
41x 1" 1/2 S Traps
1x 4" pan connector
5x 15mm blank ends
12x 15mm tees
9x 15mm straights
25x 15mm bends
11x 22mm olives
1x 22mm tee
6x 22mm bends
19x 22mm straight
7x 1" 1/2 TO 1"1/4 straight insert reducers £2 the lot
4x 1" 1/4 Straights 50p each
2x 1" 1/2 s traps under bath £3 each
2x 1" 1/4 P traps £3 each
1x 1" 1/4 p trap extended £3 each
5x 1" 1/4 45o bends 50p each
2x 1" 1/2 Washing machine traps (p trap style) £3 each
1x 1" 1/4 straight trap £3 each
8x 1" 1/2 Straights 50p each
9x 1" 1/4 bottle traps £3 each
125x 1" 1/4 90o bends 50p each
33x 1" 1/2 TO 1"1/4 straight reducers 50p each
37 1" 1/2 45o bends 50p each
31x 1" 1/2 90o bends 50p each
79x 1" 1/2 Tees 50p each
41x 1" 1/2 S Traps £3 each
1x 3"1/2 pan connector £3 each
1x 4" pan connector £3 each
1x 4" flexy pan connector unbaged £5 each
15x 4" 20mm offset pan connectors £3 each
2x 4" Straight Pan connectors £3 each
1x Convertible syphon £5-£10
9x Cooker Flex brand new still in packing Not Sure
2x 15mm Tap Connectors £3 the lot
5x 15mm blank ends £1 the lot
12x 15mm tees £3 the lot
9x 15mm straights £3 the lot
25x 15mm bends £5 the lot
11x 22mm olives £3 the lot
1x 22mm tee £3 Each
10 x 22mm tap connectors £3 Each
6x 22mm bends £1 Each
19x 22mm straight £1 each
This would be my estimate, similar to screw fix prices to be honest as they are not screw fix, however they are not new either.
I would say approxiamately £500 worth of goods.
When i looked at this and read the first post where they were loaded onto 2 pallets i thought Mmmmm
then i read the list. (i am only interested in copper fittings)
I have more fittings in the bottom of my tool box.
Around 10 years ago i bought a job lot of end feeds from a place that was closing down.
Something like 3000 22mm unions 2000 elbows 5000 tees etc, a bit (lot) of everything.
Got the lot for 1k cash and for a while i used to look at the boxes of fittings and think i'll never use all these by the time i retire. Maybe i should sell some.
I'm glad i didn't as i have run out of some and i'm down to a couple of hundred of others.
If you are staying in the trade, unless you are stuck for cash, keep them. You will use them.
about 15 years ago i aquired about 10 boxes of 28x15 yorkshire reducers and i had to buy one last week i thought at the time ill never use all those
