View the thread, titled "Master Soldering help needed for a clean solder" which is posted in UK Plumbers Forums on UK Plumbers Forums.
The problem you will find when you use silver solder is that the copper will be annealed and the solder will go a dark colour.
If you want the polished copper look, you will never be able to achieve that with the temperatures required for silver solder.
The solder melts at @ 700C and copper anneals at @ 400C.
Hope this helps
Is this still ongoing
Tin 1/2" of the end of the pipe, flux the fitting sparingly, shove it together, heat, allow to cool.
No need to add anymore solder as the solder on the tinned pipe will transfer to the fitting.
It might not be watertight but it won't come apart.
Ok well after a little trial and error today I had great results from soldering the inside of the fittings.
I give up with the pictures I've uploaded but they've turned out upside down I'm afraid.
Easier soldering the outside of the pipe than the inside of the fitting but the result is the same.
Well done on getting those jars to hang there. Bet that was harder to do 😉
You could use "solder paint" if you can still get it. This was a paste of powdered solder and flux mixed. You apply to the joint and heat with a torch. Might work.
Reply to the thread, titled "Master Soldering help needed for a clean solder" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Thread Tags
Tags Tags
None
Electronurd,
plumbill,
